St52-3 DIN 1
Ccancro
5
I am trying to find a compatable material for St52-3. I am coning up with A572 grade 60 but that is not supplied either. My only other shot at this is 516 grade 70. This material is going to be fabricated into a built up tension member for a clam shell bucket. I am just curious if anyone has any information pertaining to this material.
Thanks in advance
Charles Cancro
Charles J. Cancro
Charles,
What exactly are you in need of? Grade 60 according to ASTM A 572 is a reasonable alternative to St 52-3 in terms of mechanical properties, but necessarily for chemical composition. Most of the HSLA steels in North America are produced with a C content of ~ 0.08 instead of the 0.18-0.21 range for St 52-3. The following link shows some previous Eng-Tips discussions on this grade:
I was just trying to find out if 516 grade 70 is a safe substitute for St52-3. And if there is pre and post heating required for welding.
Charles J. Cancro
The ASTM A 516 Grade 70 is not acceptable for use in this application. The yield strength is critical to avoid permanent deformation, and for A 516 Grade 70, the YS is only 260 MPa minimum. As indicated above stick with the HSLA steel grades or even consider US Steel T-1.
The Metal Data site says that ST52-3 is equivalent to ASTM A663(45-80) and ASTM 675(45-900). This are steel for non-critical applications.
Go to this page and if you have Google use their find feature on this page. You can pay $20.00 and get an up to date report plus a lot more.
