Stable time increment control ERROR 1
jorge0894
Materials
ES
Hi everyone,
I'm working on compression test simulations with a material model defined by a VUMAT. However, my simulations are not running since the following error appears:
***ERROR: There is no element available in the model to control the stable
time increment for Step 1. Please add a deformable element to
control the stable time increment. Alternatively, you can use DIRECT
TIME INCREMENTATION to perform the analysis at a user specified time
increment.
I don't know why this is happenning, if anyone could know why, I would appreciate the help. And if you need to know some more info about the simulations just tell me,
Thank you in advance,
Jorge R.
 https://files.engineering.com/getfile.aspx?folder=2d7d27a7-fe76-453c-b6e7-b4a8f3ce2ecd&file=Captura.JPG
It seems that your VUMAT code is incorrect - Abaqus needs deformable material properties to calculate stable time increment for the analysis.
