charliealphabravo
I am doing the design for the base plate connection of a 20" diameter by 80' high stack. I think it will connect to an NH3 scrubber.
What standard/code covers these types of stacks in Canada/US? Is it 650 or some other? I would typically design the foundation and anchor rods for the building code environmental loads but I'm thinking there may also be vortex shedding loads and loads due to velocity discharge of the stack.
The foundation issues I am familiar with but I may also be asked to design the stack itself and I would like to get up to speed in the meantime. Is it acceptable to design the primary stack structure to loads from the code/standard and then delegate the nozzle and flange design to others?
Thanks in advance.
Thanks in advance.
