Gcooper79
- Jul 4, 2019
- 16
Hi I posted this earlier in the wrong forum,
I am designing a lube oil pipe system to be installed in a refinery close to the coast. The oil system is fabricated from unpainted 316/316L stainless steel pipework and painted ASTM A105N carbon steel valves with stainless steel trim (Company standard) - the flanges and valves will be connected with SW gaskets comprising of stainless steel inner and outer rings / 316 windings with graphite filler. Bolting will be ASTM A193 Gr B7/A194 Gr 2H, Xylan 1070 Coated.
My client is questioning how we protect against galvanic corrosion.
From my understanding the factors which affect galvanic corrosion are electrical potential of the materials, mass of the materials, contact surface area of the materials, process medium, and the local environment of the pipe system.
My questions is, that as the contact between the materials is relatively small (windings surface area) would there be any significant corrosion or would I need to provide isolating kits?
Thanks in advance for any advice provided.
Graeme
Graeme
