Dear experts,
My company will run a Sulfuric Acid Plant project. Our licensor require 316L material as converter and ducting shell material which will operate at 600 Celsius.
I know 316L having good resistance in sulfuric acid. But with that high temperature, will 316L suffering intergranullar corrosion since it will be exposed into sensitization temperature range?So, what is the main reason to choose this material for this operation condition, and what should I do for welding procedure?shall the welding procedure tested also with corrosion test simulating operation condition? Your opinion and experience is highly apreciated..
