We are constructing a large mat foundation (75'x90') to support several large pieces of equipment. The geotechnical engineer is recommending a compaction of 95% using the Standard Proctor Test. The contractor is saying that 95% is very difficult and expensive to achieve. I have specified 95% using either the Standard Proctor or Modified Proctor Tests for many years and I have never encountered this objection from a contractor. Has anyone had this problem? The geotechnical engineer suggested that the contractor may be confusing relative density with compaction. Thoughts?
