Doodler3D
- Jan 20, 2020
- 188
I could not find a clear definition of standard/non-standard vessel in the code. Could someone elaborate on what classifies a vessel as non-standard? Is it a vessel that does not require ASME stamping or is an unfired pressure vessel similar to the definitions in EN13445? How is the design by analysis applied to a non-standard vessel?
Thank you.
Thank you.
