StartCommand Generate CATPart from Product and save the new file
gm2gabriel
Aerospace
Jul 23, 2020
4
BR
Hello, I would like to re-open the following thread:
I am writing a macro to be used in the "Assembly Design Workbench",at some point I would like to export/convert the selected .CATProduct to a .CATPart using the "Generate CATPart from Product..." command.
This could be done with the following code:
Sub GenerateCATPartFromProduct()
Dim ActDoc As ProductDocument
Set ActDoc = CATIA.ActiveDocument
Dim MySel As Selection
Set MySel = CATIA.ActiveDocument.Selection
MySel.Add ActDoc.Product '.Products.Item(1)
CATIA.RefreshDisplay = True
CATIA.StartCommand "Generate CATPart from Product..."
Dim PauseTime, Start, Finish, TotalTime
PauseTime = 0.5
Start = Timer
Do While Timer < Start + PauseTime
DoEvents
Loop
Finish = Timer
TotalTime = Finish - Start
SendKeys "{Enter}", True
End Sub
Source:
CATIA Portable Script Center v2.0
GenerateCATPartFromProduct from gtwiki
The Sub works great, after it is finished a new window pops with the new converted part, however I need to automatically save and close this newly created part that will be used latter on. How could I do that?
If I put anything after the "SendKeys" line, for example a simple
MsgBox "Hello"
The SendKeys "Enter" stops working, as the Sub no longer pops the new windows, instead CATIA ends waiting for a "ENTER" at the "Generate CATPart From Product" window at the bottom right corner.
If possible, my goal is to "Generate CATPart From Product" with some "SaveAs" functionally, I mean: the user should not need to choose a new ParNumber for the part, or filename, or even see the new part in a new window, automatically saving the new part to a file is enoght.
