StartCommand ON/OFF instead of toggling
hadzi11
I'm working on a macro that uses CATIA.StartCommand, but it only toggles the command without a way to check its current state.
I need to: Set a StartCommand explicitly to ON (1) or OFF (0), instead of just toggling.
Is there a way to achieve this in Catia? Any advice would be appreciated!
Thanks!
hadzill,
what current state are you checking?
For example below, Script checks the current state of z-buffer setting.
In this case it will either be true or false.
Then it sets (toggles) it to the opposite.
But I think you could do a If/Then, Else, EndIf
If variibale is true (or false, whatever you are looking for) then run the startcommand, else do nothing.
Sub CATMain()
Set settingControllers1 = CATIA.SettingControllers
Set visualizationSettingAtt1 = settingControllers1.Item("CATVizVisualizationSettingCtrl")
visualizationSettingAtt1.AllZBufferElementMode = Not visualizationSettingAtt1.AllZBufferElementMode
visualizationSettingAtt1.SaveRepository
End Sub
something like
Sub CATMain()
If visualizationSettingAtt1.AllZBufferElementMode = True Then
CATIA.StartCommand "Fit All In"
Else
End if
End Sub
