Not sure what forum to post this in, so I'm going to ask this here. I know that static electricity damages electronics, however electronics (computer monitors, flat-screen TVs, etc) are packed in styrofoam. Why are the electronics not damaged by the static generated by the styrofoam, during shipping?
I'm asking, because I'm preparing to ship a prototype electronic device (garage-built) for air-shipment, and the device case will be packed in styrofoam (see details below). I don't know much about static-electricity dynamics, so I'm just checking to make sure the styrofoam won't "zap" or otherwise damage my device during shipment.
In case it's important, there are the full shipping container details:
[ol 1]
[li]Device is a small appliance (like a printer), that has static-sensitive components.[/li]
[li]Device is disassembled, and the parts are placed in molded cavities in an anti-static pink foam block (a block of pick-foam).[/li]
[li]The above (pink foam and device) is inside a sealed plastic case.[/li]
[li]Plastic case is then placed in a styrofoam box (with form-fitting styrofoam top); some paper cushioning material is between the gaps of the plastic case and styrofoam box[/li]
[li]Styrofoam box is then put into a corrugated cardboard shipping box; some paper cushioning material is between the gaps of the plastic case and styrofoam box[/li]
[/ol]
Does the above look static-safe?
Thanks in advance!
[ol 1]
[/ol]
Thanks in advance!
