Static Head
Mash18
ZA
Hi All, im currently Studying for API 510 & trying to calculate metal loss as per ASME VIII Div.1 UG-27(c)(1), However I am struggling to understand the Pressure conversion part. (refer to attachment)
Does this mean that Static Head = Given Value x ID + 2 X Corrosion Allowance??
If as stated, the ID is relaative to static head value, why was 0.433 used instead of the ID? Or is that just part of the example
Mash18, Density of water = 62.4 lb / ft^3. Per cubic inch = 62.4 / 12^3 in^3 / ft^3 = 0.036 lb / in^3
Pressure of column 1 ft high = 0.036 lb / in^3 * 12 in / ft = 0.433 lb / in^2 / ft
Diameter of vessel, ft = (48 + 2 * 0.125) / 12 = 4.0208 ft.
You can take it from there.
Mike
Note that the 2*CA should have been divided by 12 also, as SnTMan has above.
The 0.433 is for water at "normal" conditions, and may vary depending on what is in the vessel.
