Raj Adrika
- Feb 13, 2021
- 8
I have power transformer( 25MVA, Delta/wye, 138kv/4.16kv)and the Xo is connected with 160ohm , 15A for 10 sec NGR. I have metering PT ( 3 single phase units, two bushings N.S.V 15kv, 110 kv bil, H1-H2-2.4kv, SEC. 120V ratio 20:1)which I am planing to connect L-N. In such case which type of single phase 50kva SST I could select. Could I select 4.16KV Y/2.4KV, TWO BUSHINGS ( Both bushings to be same insulation)and connect L-N. Or I have to select L-L (Delta) transformer and connect VT L-N or L-G (any option).
