I need to supply steam to a heater and an eductor in a small enclosure (20"x20"x8") that is attached to a vessel nozzle. The steam flow through the eductor will be the motive fluid to create a suction to get our sample from a flue gas stack.
The vendor indicated they'll need between 20-80 psig steam for the eductor. I located a nearby 3/4" 150# steam pipe that ultimately drops down to steam tracing. I intend to tap into this line and run piping about 6' vertically to a deck where I will put a steam reduction station. The 3/4" pipe will be split into two 3/4" branches with each going to a Fisher 95H steam regulator. The steam will be adjusted to the needed pressure then exit each regulator via preinsulated stainless steel tubing. The tubing will travel vertically about 35 feet to the enclosure.
Questions:
1. The operator indicated the line I want to tap into is a 150# steam line. I did find iso's and drawings to agree with this. Which pressure and temperature do I use for calculations since there are no gauges or indicators? Do I assume saturated steam to be conservative or superheated? If I assume saturated, then any heat loss will generate condensate immediately. I do have some data from the plant stating that when designing for the 150# steam system, use the following for utility characterisics:
Process 410 deg F and 150 psig
Mechanical 450 deg F and 170 psig
Considering the tap off the main header could be a long distance from my work area, I'm concerned that I may be using inaccurate data.
2. Where should I install steam traps in this piping? I intended to put one in the common piping upstream of the two regulators. Is this an appropriate location considering I'd have a reverse flow situation. I assume there will be condensate formation at the upstream side of the regulator (is this correct?) If so, that condensate wouldl be flowing against the steam flow to the regulator.
3. Do I need another steam trap before I make the 35' climb in pre-insulated SS tubing?
4. Do you think a 3/4" 150# steam line would be sufficient to supply a constant 20-80 psig stream to the eductor and a branch for a temperature regulated enclosure heater?
I am a new mechanical engineer and work with a firm that is primarily an electrical company, so I have no experienced people to turn to. This adds a bit of complexity to my work, but having you guys is an asset.
Thanks for your time.
Questions:
