Hi There,
I was wondering if anyone had any insight into how to allow for thermal expansion/contraction of structural steel beams bearing on CMU or Concrete walls. I've had some issues with cracking at the bearing pocket where the beam has engaged the bearing plate as it expands/contracts and cracked the wall. Our current detail uses a bearing plate with oversized holes, plate washer, and hand tightened anchor rods. The steel beam gets welded to the bearing plate. Even though the holes are oversized, I believe the grout below the bearing plate is still engaging the wall below. Has anyone had any experience in with a bearing pocket detail that provides stability of the beam while still allowing thermal movement of the steel?
