Why does steel flake when it corrodes from a metallurgy standpoint? I was in a below grade steel framed parking garage where all of the beams were fireproofed. I noticed that several beams were visibly wet (fireproofing was soaking) and in some cases the fireproofing had popped off the beam. At one particular beam, the beam flange appeared to have expanded significantly to the point where the flange was composed of many thin layers of steel. I was able to chip these layers off with my finger. I am under the impression this is a pretty advanced form of corrosion. My question is, why from a metallurgy standpoint does the steel separate into these layers? Also, are there any good guidelines for repair of such members?
