Fellow engineers,
I am running into a problem in the field where beam penetrations through my steel beams need to occur. Our detail shows that the depth of the penetration can be D/3 (D = depth of steel beam) and the length of the penetration is 3/4*D.
This rectangular penetration has fillet welded plate top, bottom, and sides.
Is this somewhat of a generic penetration requirement that every engineer uses or does anyone use different (whether it is more or less stringent) than what I have described above?
I am curious to know because unfortunately, I might be forced to provide bigger penetration than what is described above and I am trying to understand where my comfort zone lies.
Any thoughts and/or suggestions would be appreciated.
