JStructsteel
- Aug 22, 2002
- 1,438
When adding a steel beam to header off a large opening in a CMU wall, do you folks add any mechanical connections to the beam to "capture" the CMU, or do you just rely on grout/friction or horizontal span to resist any lateral load?
I was thinking dowels or studs on top of the beam, but that could get in the way of the installation. I also thought angles welded to the underside of the top flange to capture the CMU. Lastly I was thinking holes in the to flange to install expansion anchors or epoxy dowels at the grouted cells un into the wall.
Thoughts?
Thoughts?
