phamENG
- Feb 6, 2015
- 7,626
AISC 360-10, J7a - Bearing Strength. The surfaces in contact are limited to a stress of 1.8Fy. Commentary is silent on the reason. I've found a few old threads - mostly mechanical engineering forum - discussing limits on Hertzian Stress. They vary from as high as 5.5Fy for point contact in an Italian code to 1.8Fy as that is when "plastic flow takes place," but most limit it at 2Fy.
Anyone know if that's the source for the AISC limitation? Any insights into AISC's decision making process for 1.8?
Thanks.
Thanks.
