JD P.E.
- Oct 17, 2021
- 79
Working on a project on free time to increase understanding of structures.
After applying wind loads I'm getting a deflection of about .600 around the center of the circled column (in weak axis direction). Likely would be where a roll up door would be, but with framing added to support door.
Would you consider .600 excessive for end column weak axis deflection? Pushing close to L/250. Columns are 14 feet tall.
Considering adding some sort of cantilevered wind column since I have room.. but wanted other thoughts first.
