kenre
- May 23, 2005
- 300
I an designing a small high performance 2 stroke engine.
For reliability and longevity reasons i will be using a steel bearing housing in place of the cast alloy housing normally used, less thermal expansion and higher stiffness to ensure greater life of the bearings.
Full hard O1 steel can be used, but i would like to avoid the heat treatment and internal grinding needed.
So looking for something with a bit of strength and exellent machinability.
A couple of alloys i have looked at are P 20 (M200), M315 and
4140 Ultimate, Bohler uddeholm steel.
Any other suggestions? or real world machining experience?
First few manual machined, and then to CNC once design is completed.
Was told it couldnt be done, so
i went and did it!
i went and did it!
