bvbuf
- Jan 22, 2003
- 30
I've got a project with a 6" HSS column in a 6" metal stud wall at the slab edge. I dropped the footing (-1'-4") and I'm forming and placing grout around the base plate (for concrete cover) after it is installed (top of grout is at -0'-8"). Now what about the face of the column from -0'-8" to 0'-0". The face of the column IS the edge of slab meaning the entire face of the column is exposed to weather or earth unless I build some kind of bump out from -0'-8" to 0'-0". And the architect would hate that. What do you do?
