Hi everyone,
I have this existing building with above-grade exterior concrete block walls and steel columns. The steel columns werr not air sealed and you can feel air draft through at the web and flange corner. The attached sketch illustrate the situation.
How do I air seal the gaps between the columns and the block walls? What details and materials would you recommend?
