Veer007
- Sep 7, 2016
- 379
As a Steel Detailer, I would like to know, What are the primary responsibility of steel detailer when details are missing?
Thanks in advance!!
Thanks in advance!!
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Yeah, you are almost correct, I have been working for AISC, CISC, AS-NZS standards for past 6 years and seeking info. that I couldn't ask EOR as drawings were mentioned as "connection to be delegated design", that's why I find support elsewherehuman909 said:Also I believe he might be drawings for different countries (Canada and Australia at least) which suggests to me he could be an overseas outsourced draftsperson rather than a 'local'
Veer007 said:Yeah, you are almost correct, I have been working for AISC, CISC, AS-NZS standards for past 6 years and seeking info. that I couldn't ask EOR as drawings were mentioned as "connection to be delegated design", that's why I find support elsewhere
I have been using Tekla structures for yearshuman909 said:Can I ask what software you are using in your day to day work. It should give me a little bit more background. (Years ago I did steel detailing using Autodesk Inventor, not really the best tool for the job but effective in mixed mechanical and steel construction. I've also used Autodesk Advanced steel. Tekla is very common here but I haven't used that.)
