steel plate
sudu
8
i work for a company based in New york, can someone tell me where we can get steel plates , for eg 3/4"x10 1/2"x10"...i don need supplier information for large quantities, i need someone who will give one cut length of this deimension
I suppose,if you talk to any fabricator , he can give you a piece free.
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
We normally purchase small quantities for welding procedure qualification from any of our Texas plate stockists. The more cuts - the higher the price. I would assume it would be the same for East Coast stockists.
Most fabricators would buy HR flats 3/4 x 10, and cut off the 10-1/2" pieces as needed.
Steel service centers are happy to supply cut rectangles to exact dimensions, but charge a little extra for the cross-cuts and for handling the 'small' pieces.
Either way, just fax a RFQ describing what you want to all the service centers you can find, and pick from the quotes. Not rocket science.
Mike Halloran
Pembroke Pines, FL, USA
Many/most steel service centers won't even talk to you - unless you know someone. There is a national franchise that handles this exact problem - something like Metals R Us - can't remember their name.
A welding fabricator might help you - they always have loose pieces setting around.
Around here I would try Southwestern Paint Panels for something that small.
See if you can find a small "mom & pop" or "father & son" machine/fab shop in your area. They would fall all over something like this. They would make a buck and you will save a bundle.
rmw
