BMart006
- Mar 20, 2017
- 61
I'm reposting this to this forum because I imagine there are quite a few people here with structural fabrication and coating experience.
Let's say a paint product data sheet calls for a surface profile of 1-3 mils (range is made up and doesn't actually matter). I know that some power tools (SSPC-SP3) can produce a surface profile in steel such as needle gunning, but is a powered wire brush (which is also part of -SP3) capable of creating a surface profile? My thought is that it would be creating long canyons, but not necessarily sporadic peaks and valleys similar to what you would see with abrasive blasting. If you have any resources/standards documenting an answer that would also be helpful. Reading SSPC-SP3 is a bit vague on whether this would get me to a surface profile. Thanks!
