Coastalberry
Industrial
- May 23, 2023
- 2
Hey guys,
Check out the images!
For this project I need to support 2 glass tabletops with weights of 28kg (left) and 38kg (right) against a window. The frame length will be a long 4.5 meters and I am only able to anchor the frame on the left and right side of the frame to the columns in an office since I cannot alter or touch the window or the window frames. I will be having a 3rd support point using steel cables anchored in to the ceiling to support the frame in the middle.
This is initially designed using mirror polished stainless steel tubing (3x3cm) (2mm thick) mainly for aesthetic purposes as well as durability. They will be 4.5m long tubes anchored from column to column.
Before I pull the plug I thought to see some opinions about aluminum tubing instead of ss in terms of its structure capability as well as ease of cutting and drilling etc and sacrificing the aesthetic.
