minus3db
- Sep 27, 2018
- 4
I am inspecting some equipment which includes steel wire braided cables coming into a control panel via cable glands.
The cable glands are not the armored cable type glands where the steel braid is grounded inside the gland; rather they are the normal pass-through type of glands. Each cable passes straight through the gland into the box, where it is stripped back and the conductors are terminated. The steel braid for each cable has been twisted together, covered with heat shrink, and terminated onto a ground bar. All of the work has been done very neatly.
Is this acceptable? In other words, is it an absolute requirement to use armored cable type glands? The steel braid has still been bonded to the rest of the enclosure via the ground bar; it's just not using the gland to do so.
Any thoughts on this are appreciated. Thanks.
