Stellite deposition Power valves
Isha90
88
Customer requirement 3.2/2.1 mm Stellite#6 deposition [HF], F22 Body material, Class 1500, application 300 Mw power plant, as per API 600 1.6 mm & API 602 1 mm min.HF thickness, is there any standard for power valve to check minimum HF requirement on integral Seat for Globe valve.
