Stelliting
JohnsonMadukayil
17
Anyone having a desriptive procedure on Stelliting, can you please show me the way?
Stellite is a proprietary "super" alloy owned by Deloro Stellite ( It is prepared in powder form and thermal spray-deposited onto surfaces. This is known as "Stelliting". The resultant surface is hard and both corrosion and wear resistant.
There are a variety of hard alloys which can be applied in such a manner for such purposes.
"Stellite" is also commonly applied by welding. There are several different compositions of Stellite that can be used. The main difference is the carbon content. This allows you to select an overlay that has the hardness-toughness properties that are best for your application.
Check with Stellite for material properties and application information. If you are looking for a source to apply "stelliting", try searching under: Hardfacing, Welding/Overlaying, Metalizing, Thermal Spray
