  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Stiffened plate strange modes.
Alexkoguar
Aerospace
Feb 13, 2021
6
IT
Hi everyone 👋😀, i have created a stiffened plate(with ribs and spars)clamped at one end(a wing model for flutter analysis), the plate is meshed with bar2 and quad4 element, When i run the modal analysis in nastran i found strange in plane modes that i cannot completely eliminate. Can anyone help me please? The right sequence of frequencies in Hz is: 4/8.9/25/33/70/76/134/144.
 https://files.engineering.com/getfile.aspx?folder=43aba2df-4373-4a31-922d-50566d9d6280&file=pannello_ala.bdf
I can offer no advice on the specifics, but trying to visualize from your one-line description- I would check that masses and stiffnesses in all directions were appropriate- specifically watching for something like m versus mm, ft vs inch, E vs Fy, etc.
Thanks, i dont know how to block the membrane action efficiently(strange because impose the bending element). When i constrained two free ends it works fine for the first frequencies and if i block all the in plane dof the frequencies are wrong.
The nastran input file/code doesn't mean a lot to me....I don't work with that program. (And I cannot tell what the boundary/support conditions are from it.)
The pic is helpful.....but I cannot tell what the boundary/support conditions are there either.
Just guessing based on what you posted: you likely (in order to make the model stable) have some sort of in & out-of-plane restraint/supports at some points along the perimeter. With that set up, you will get a lot of lower modes participating for the out-of-plane modes.....but the in-plane stuff will mainly be with higher modes (and likely low mass participation). That is, assuming you are talking infinitely stiff restraint in the in-plane direction.
You likely aren't interested in the in-plane stuff.....so you can just ignore it if you want, or come up with a in-plane stiffness for the supports that is accurate.
Thanks WARose, but when i constrained the nodes for the in plane dof, the natural frequencies of bending and twisting out of plane are wrong. I used shell elements and bar elements.
