Stitched vs woven fabric advantages and disadvantages
acerox
New member
Jun 20, 2015
7
Hello Everybody,
I have been coming around this question for a while. I have found a thread about it but I was hoping to get some more ideas.
Why would you use woven fabric instead of UD, for example a layer of woven vs biax (two UD stitched together)? I fail to the see the advantage of woven vs stitched (non-crimp) fabrics.
I have developed a list of advantages and disadvantages. Let me know if I have missed something:
(0,90)-UD Stitched better than (0,90)-woven.
• Better tension and compression stiffness/strength due the lack of crimping.
• Better drapability. Lack of crimping allow better conformance with round surfaces.
• Higher fiber to resin ratio.
• Easy to wet in either hand lay-up or infusion.
(0,90)-Woven better than (0,90)-UD Stitched.
• Better resistance to crack propagation since the crack would be to propagate through the fibers (in an individual layer).
• Stitching may induce fiber fracture in stitched fabrics (I am not sure about this one).
• Better peeling resistance (why would that be? Due to nesting of the plies?)
From a manufacturing point of view, it should take the same time to add a layer of woven fabric than a biax fabric. So not really an advantage there.
I know that a specific aerospace company replace two UD layers 0 and 90 by a layer of plain woven (90,0). So there must be an advantage there, is the better resistance to crack propagation (definitely not a negligible characteristic) the main reason?
Thanks!
(old thread -
Fibers can peel out of UD surface plies for several inches or feet away from the damage location. Woven is preferred for a surface ply for this reason. Fibers cannot peel out because they go under a 90 degree tow every 1/8" or so. Stitched fabrics have a stitching thread to hold them together so there is still some fiber crimp that occurs that lowers the compressive strength compared to UD prepreg.
UD tends to split under impact damage, particularly on the back side, and so typically has larger damage areas than fabric laminates.
Thanks all for the good answers. It does seem to be damage tolerance the main advantage of woven versus UD or stitched fabrics.
