DoubleStud
- Jul 6, 2022
- 481
Do you guys have a detail you can share how you frame deck column with natural stone veneer (6" thick including mortar) all the way to the top and above the deck? I never like this scenario and it is very hard to transition from concrete pier, to column to wood with stone around it. In the past I have always used HSS column to make sure the column would not rot, the furring will eventually rot. Got a detail to give me ideas? Here is a random photo I found online.
