h-badawy
- Jan 8, 2015
- 132
dear experts
I have confusion for two issue regarding story drift:
1-as per ASCE 7-10 Section 12.8.6 requires: “Where allowable stress design is used, Δ shall be computed using the strength level seismic forces specified in Section 12.8 without reduction for allowable stress design.” this meaning that only the case of allowable design Δ will be computed from ultimate load combination or in all cases of design i have to get Δ form ultimate load combination ?.
2-in the same item above figure 12.8.2 (story drift determination) he said "elastic displacement computed under strength-level design earthquake forces" the meaning from (elastic)that all of the concrete elements on the 3D model should be un-cracked (without any modifiers) to get the elastic displacement ?
Thank you
Thank you
