Strain Rate Caused by a Vehicle Moving on a Bridge
Logan82
212
I have a road bridge with a simply supported beam. What is the equation for the strain rate of the fibre in tension in the middle of the span caused by a vehicle crossing the bridge?
An easy way to determine the strain rate would have been to use the formula developed in this thread where the formula is: ε/t = ((V)*12*y) / (L^2), where V = velocity, y = distance betweeen neutral axis and fiber in tension, L is the length of the beam. But I am looking for a less conservative formula.
You have mistranscribed the equation. All you need is to work out the reaction force at each end as a function of V*t, hence calculate the bending moment at the centre of the span, and then use M/I=sigma/y, and E=sigma/strain.
Cheers
Greg Locock
