Strain Rate (Simple question) 3
Logan82
212
I have this beam:
Would you say the strain rate (Δε/Δt) of the fiber in tension of this beam would be:
Δε/Δt = V / L0 = (0.00583 m/s / 7.11 m) = 0.000972 s-1
Note: The beam will stay in the elastic realm.
No, not at all.
Strain in the tension fiber is related to the bending moment generated by the applied loading. Assuming loading at the center of the span, δ=M*L02/(12*E*I), σ=M/S (using the US convention of S as the elastic section modulus), σ=E*ε.
Some algebraic substitution using the time-dependent displacement will give your strain rate. Δε=(12*I*V)/(S*L02)
just call me Lo.
Logan82,
Wrong formula. That formula would work if the beam is acting in tension, eg like a 7.11m long rope being stretched at that rate.
The answer for a beam depends on beam size. A smaller beam will have a higher strain rate than a larger beam.
Thank you all! I felt something was off. I could not find some already built formulas of strain rates for different beam configuration. Do you have a website or book that shows the different strain rate formulas?
Just work it out.
Calculate the resultant flange stress at 5.83mm of beam deflection.
Convert that stress to strain. That’s your strain rate.
to clarify tom's post ...
1) calculate the displacement, d, for a 1000 lb (or 1000 N) load,
2) calculate the stress, and strain, s, in the outer fiber,
3) scale so that for a displacement of 5.83mm, the outer fiber stress (or strain) is s*5.83/d
Thank you very much everyone! Your help was appreciated.
