Sparky4598
- May 4, 2024
- 18
I am working on a guard design that needs a tubular steel section about 24" inside diameter and 36" long. I am wanting to make the tube section 1-1/2" thick, but no standard pipe or tube suppliers that I can find appears to be close to that.
My next thought was to make it out of laminated steel rolled plates. Say 2pc @ 3/4" thick or 3pc @ 1/2" thick so it is easier to fabricate. My concern is impact strength though. Should I expect the laminated configuration to have similar strength to a solid section or would it be drastically (say more than 30%) different?
Is this something that would likely be considered extremely difficult to model with FEA?
Any other thoughts or suggestions as to fabrication options?
The guard is a safety device to protect workers in the vicinity should the shaft coupling inside catastrophically fail.
Thanks for your time!
