Staszkinson
According to Abaqus, it is well-known that he needs true stress - true strain input data in the material module.
In this case user have to convert engineering values for true stress - true strain values manually.
What type of data should I use in Ansys Workbench - engineering stress-strain or true stress-strain? I want to define steel with bilinear isotropic hardening.
I can set only yield strength and tangent modulus. As can I see bilinear isotropic hardening is calculated according to young modulus from "isotropic elasticity" module.
Thank You.
Thank You.
