General question about using packers and shims between precast concrete elements to provide a gap for forming a grout or mortar bed.
Is there any risk with using a stiff (i.e. steel) packer that there would be a concentration of force through the packer under applied loading or post-tensioning (and potentially causing issues with bearing failure or splitting in the concrete)?
Is it better to use a softer material (e.g. plastic) to ensure the grout or mortar takes up the load?
And to what extent does the shrinkage compensation or expansive behaviour of the grout/mortar have on alleviating this?
