How would one approach calculating the stress induced in an adhesive being used to secure two members for a shear or torque? Think two disks adhered together, where one disk is spun and the other is fixed. How would you calculate the stress experienced by the adhesive to determine if there would be a failure in the adhesive.
There are several wood-wood connections that I've seen in residential construction that are just glued together and call it a day, but how would you actually check this?
