Stress Wave propagation
loyal979
47
If you can use implicit solver instead of explicit it should solve the problem. Or use increased damping.
Thank you. I won't be able to use implicit for this analysis.
for increasing damping. Do you mean the Viscous damping in the step module?
Not really, I’ve actually meant material damping specified together with other material properties.
Rayleigh damping, so alpha and beta coefficients is what you need.
So: *Damping, alpha=...value, beta=....value
You can do this in the property module also in CAE and in Mechanical/Damping
Thank you both for your help. it did work with defining material damping.
