purode333 said:
Which will be the strongest weld to be consider, Butt or fillet?
This isn't a well worded question for the following reason - A butt
joint is a type of joint and a fillet weld is a type of weld.
A butt joint can only be welded with a groove weld, that groove weld may be complete joint penetration (CJP) or partial joint penetration (PJP); it cannot be welded with a fillet weld.
To further expound upon this, there are essentially 5 different joint types: butt, corner, T, lap, and edge.
And there are four major weld types: CJP groove weld, PJP groove weld, fillet welds, and plug/slot welds.
The only joint that can truly use either a groove weld or a fillet weld is a T-joint (a corner joint would result in a fillet weld on only one side which is less than ideal). In designing the T-joint both the groove weld and fillet weld could be sized to develop the full strength of the base metal (this would require a CJP groove weld, which by definition will develop the strength of the base metal). However, CJP (and PJP)groove welds perform better in fatigue applications than do fillet welds.
