StructEng20
- Apr 6, 2018
- 2
What are other engineer's takes on diaphragm modeling of a typical untopped metal roof deck?
Consider 1 1/2" Vulcraft Type B, 20 GA (design thickness = 0.0358in). I use RAM Structural System's Frame module for my lateral analysis of steel framed buildings with the following parameters for this type of roof deck:
Effective Thickness: 0.0358 in
Poisson's ratio: 0.30 (same as steel)
Elastic Modulus: 1820 ksi
Note that the Elastic Modulus is an Effective Elastic Modulus (E') based on recommendations by Bentley:
I model this as a semi-rigid diaphragm in RAM Frame, but I'm uncertain whether this is accurate or whether untopped metal roof deck should be modeled as a Flexible/None or Pseudo-Flexible diaphragm where the diaphragm/frame loads are assigned by the user? Load distribution for a Semi-Rigid diaphragm is determined by the parameters listed above through FEA. However, by definition, this qualifies as a Flexible diaphragm per Building Code and loading would distribute based on tributary areas of each frame.
Thought I'd poll the audience to see other's perspectives and practices.
Thanks.
Thanks.
