doctorbahman
- May 13, 2013
- 1
Hi friends
could you please help me by answering the following questions:
1)What does the ~ stands for when it comes before a node label?
2)Why "solve a equation block" happens?
I've brought my LOG file as you can see in the following:
SAP2000 v14.0.0 Advanced
L I N E A R E Q U A T I O N S O L U T I O N
FORMING STIFFNESS AT ZERO (UNSTRESSED) INITIAL CONDITIONS
TOTAL NUMBER OF EQUILIBRIUM EQUATIONS = 65388
APPROXIMATE "EFFECTIVE" BAND WIDTH = 882
NUMBER OF EQUATION STORAGE BLOCKS = 4
MAXIMUM BLOCK SIZE (8-BYTE TERMS) = 16696768
SIZE OF STIFFNESS FILE(S) (BYTES) = 509.879 MB
NUMBER OF EQUATIONS TO SOLVE = 65388
* * * W A R N I N G * * *
NUMERICAL PROBLEMS ENCOUNTERED DURING EQUATION ASSEMBLY:
TYPE LABEL DOF X-COORD Y-COORD Z-COORD PROBLEM VALUE
Joint ~644 UZ 44.196521 30.589871 23.621076 Diag = 0 --> 1.00E-10
Joint ~644 RX 44.196521 30.589871 23.621076 Diag = 0 --> 1.00E-10
Joint ~644 RY 44.196521 30.589871 23.621076 Diag = 0 --> 1.00E-10
Joint ~640 UZ 42.283309 30.046561 19.350000 Diag = 0 --> 1.00E-10
Joint ~640 RX 42.283309 30.046561 19.350000 Diag = 0 --> 1.00E-10
Joint ~640 RY 42.283309 30.046561 19.350000 Diag = 0 --> 1.00E-10
Joint ~641 UZ 44.495740 29.770257 14.850000 Diag = 0 --> 1.00E-10
Joint ~641 RX 44.495740 29.770257 14.850000 Diag = 0 --> 1.00E-10
Joint ~641 RY 44.495740 29.770257 14.850000 Diag = 0 --> 1.00E-10
Joint ~642 UZ 45.426600 29.519323 10.350000 Diag = 0 --> 1.00E-10
Joint ~642 RX 45.426600 29.519323 10.350000 Diag = 0 --> 1.00E-10
Joint ~642 RY 45.426600 29.519323 10.350000 Diag = 0 --> 1.00E-10
Solving 4 equation blocks
Block 1 by block 1
NUMERICAL PROBLEMS ENCOUNTERED DURING EQUATION SOLUTION:
Joint 20575 RY 74.912173 42.000000 22.850000 Lost accuracy 6.3 digits
Block 2 by block 1
Block 2 by block 2
Block 3 by block 2
Block 3 by block 3
Block 4 by block 1
Block 4 by block 2
Block 4 by block 3
Block 4 by block 4
NUMBER OF EIGENVALUES BELOW SHIFT = 0
A N A L Y S I S C O M P L E T E
Block 1 by block 1
Block 2 by block 1
Block 2 by block 2
Block 3 by block 2
Block 3 by block 3
Block 4 by block 1
Block 4 by block 2
Block 4 by block 3
Block 4 by block 4
