Mateus_R
- Mar 15, 2018
- 48
Hi everyone,
I have a question about how to construct a structure frame that has attached several machined components that has some tolerances to respect (For example: attached in the structure there is 4 supports to connect other component using pins, and the hole where the pins are going to be fixed have to be in tolerance with the other supports).
I think we can do it in two ways:
1) Machine all the components, weld them in the respective piece of structure and then weld all the frame together. To weld all the components i would use a jig to respect tolerances and dimensions. In this case I'm afraid about the thermal stresses induced by the welding process.
2) Use raw components and weld everything. After welding, machine the components (For example: the diameter of the tubes where the pins are going to be placed), in order to guarantee tolerances and avoid thermal stress due to the welding process. The problem here is to machine components that are now part of a big structure and to do it, its requested some special tools (like a drill with an arm, or something similar).
The 2) option is reasonable?
Thank you for your comments.
Kind Regards.
Kind Regards.
