Study of an ironing device
Boby2
Student
Apr 3, 2025
17
The figure shows a device for ironing, or other finishing operations, a roll of fabric.
The fabric is fed by the braked drum A, guided in the horizontal section by the idle rollers C and D and collected by the motorized drum B. In the horizontal section, the fabric is pressed by the movable steel plate E, of mass 30 kg, against the fixed plate F, also made of steel. The connecting rod H is hinged to the plate E and in a barycentric position and to the frame of the machine M.
• Calculate the crushing load on the fabric for a connecting rod angle of 45° when the machine is in operation.
• Taking into account a load acting on the fabric between the feed drum (braked) and the ironing device T0=100N, calculate the increase in load downstream of the device.
• Make a construction drawing of the Plate (E), Connecting Rod (H), Attachment to the frame group.
Assume the steel-fabric friction coefficient f=0.15
I hope someone can give me a hand.
In my many years of experience I've never heard the term "barycentric". I had to look it up.
The geometry leads to self-energization, which contributes to both the "crushing load", and if we guess that T0 is tension somewhere, that as well.
I guess that "construction drawing" is somewhere defined in the text in this context.
Unfortunately, that's the way the design is: it's a task that requires the construction of machines and as such, one has to make assumptions to solve it.
One can either use a differential equation or use an iterative solution.
The iterative solution is as follows:
The initial guess is that the 30kg mass provides a friction force of 0.15*30*g that is added to the 100N that is required to overcome the feed drum.
When it does this it also provides a down force due to the reaction at M. Being that the angle is 45º the down force due to friction should equal the friction force.
This force is added to that provided by the mass, which increases the friction force.
As long as each increment is smaller, the solution will converge.
For example, if the link H is steeper than about 81.6º then the machine will be self-locking.
this is my solution but, the dimensions 200 and 400 mm are the length and width of the moving plate?
The symbol T is usually reserved for a tension, and in your own problem statement it's the tension in the fabric, since it's between the feed and the uptake
how is the reasoning valid and is the solution correct?
on the crushing load, I thought that since the force acting on the mass is known, multiplying by the contact area A=200 400 I obtain the crushing pressure.
Friction generally is insensitive to pressure. The exceptions are for elastic materials in contact with rough surfaces. Since this is to be used for ironing fabric, the surface would certainly be mirror smooth eliminating that exception. There is no need to calculate the applied pressure for determining the forces on the plate E or in the connecting rod H.
This is a similar linkage for the purpose of keeping a door in position:
You should be able to create a cardboard copy of the ironing system using some weight and see what happens when you have the connecting rod at different angles. You should find that as it gets steeper you need to push down on what matches point M to maintain the angle, and if the connecting rod is horizontal, you won't have to push down at all.
ok I understand but, could the solution I posted be ok?
This is my solution.
Your T0 should be a tension, so it's perpendicular to the crushing force you calculated
If the solution was iterative or an ordinary differential equation then I would know your solution was correct.
Also, the rod is not supporting any of the vertical weight, so the second paragraph of your solution is certainly incorrect.
the solution made by me is wrong, so what is the exact solution because I am not understanding how to set it up. Thank you all.
Refer the following video to see how the loads are to be accounted for. I think you misunderstand creating a free body diagram.
Where is the horizontal component of the friction from the fabric being pulled across the iron?
Also note that the connecting rod does not support any weight - a free-body diagram is of the individual pieces, so the steel plate and the connecting rod should be handled separately.
the friction force is directed along the fabric
I was asking you to separate the two parts into their free bodies so that you can see that there is no weight component in the connecting rod.
I don't see that horizontal force being applied to the connection to the rod, so it cannot be properly accounted for in the diagram.
so I separated the two bodies with force
There should be forces on both ends of the connecting rod and forces on the steel plate where the connecting rod connects.
