BEMPE16524
Hi All,
I have a system like this:
-variable displacement pump maximum 360cc.
-operating pressure 200-220 Bar
-Calculated system flow at 1800RPM at 220 Bar is 648 lpm.
-the pump is needed to run a hydraulic motor only.
-the pump and the hydraulic motor location may not be too far apart (around 2 meter max, using flex hose)
What should be the flow rating of my suction filter? Should I use the 648 lpm as reference? T.I.A
R.Efendy
R.Efendy
