Dear All,
I have a requirement to replace a sanitary water pump(centrifugal - submerged pump and motor)to an above ground centrifugal pump. The pump flow rate is 4 m3/hr and the head is 21 meters. The suction pressure available is - 0.4 kg/cm2g (negative).The new pump suction will be in a pit below ground.
My question would be:
1. Is it common for a centrifugal pump to handle this negative suction pressure?
2. Do I need to opt for a self priming pump or just the normal centrifugal pump?
Thanks in advance.
Tilas
Thanks in advance.
Tilas
