Hello Guys
I need some guidance regarding Super Duplex Forging SA-182 F53 (UNS32750).
We are in process to procure forging to build ASME U-Stamp, High Pressure Filter Vessel. However, we are having issues with this material not meeting Tensile (116 KSI) and Yield (80 Ksi) as required by ASME SA-182 Ed.2019 specification. Forging are almost 9-10" thick and 24 " diameter.
Our supplier is getting Tensile 113 KSi and Yield 77 Ksi. These strength values are acceptable per ASTM A-182 but not per ASME SA-182. Our Supplier has tried re-heat and retest but still no improvement.
Undoubtedly, for ASME U-stamp vessel, all pressure boundary items has to meet "SA" spec.
Now question is;
1. Is there any exception or way we can use this material(ASTM A-182 F53) and still U-Stamp the vessel?
2. Does anyone had an experience with this material and can advise some inputs for forging process itself which can result the required mechanical properties?
Now question is;
