Whit regards to superheater coil design I have two questions
1- What is the linear velocity of the steam through the tubes of a superheater coil and its relation to the linear velocity of the same steam through the in and outlet collectors.
2- What are the ratio limits wherein both velocities should operate in order to assure a good steam distribution between the superheater coil tubes. The Perry advices a ratio of 10
