Jmeng1026
- Jun 11, 2018
- 59
I have a 22' long triple 1-3/4" x 18" microllam lvl that will be bearing on a 2x6 wood stud wall on one end and a p.t. 6x6 wood column on the other end. The lvl is support the end of a 28' long truss. So there is a 14' tributary load (60 psf snow load and 10 psf deal load) on the lvl. This is for a carport.
What is the best way to secure the column to the sono tube? A simpson post base or some kind of angle iron bolted to the column and sono tube? The contractor doesn't seem to like simpson post bases and thinks angle iron is stronger and a better option.
What is the best way to provide lateral support? Would putting a diagonal from the wood column to the bottom of the lvl work?
